Installing SS brake lines - question
    So I've got the whole rear subframe out, installed the inner SS lines, but realized I'm going to have a hell of a time attaching the other end to the trailing arm hard line. It has no swivel or pivot on the end, and I can't rotate the trailing arm to tighten it on the line, so what do I do? The line can't twist that much, it'll just undo itself.
    Thanks!
    Turn the fittings on the hard line that is attached to the trailing arm .
      Yeah, I'm a tool. I forgot the hard lines had flare fittings that could be turned/tightened. Thanks Teaguer.
