Problem with Brakes
  • jms16v
    • Dec 2006
    • 314
    Problem with Brakes
    I went to take the car for a drive and when I hit the brake pedal, it was very soft and went almost to the floor. When I let go of the pedal it returned to the normal position very slowly. Any ideas what I should do first? I'm guessing it could be the master cylinder or I just need to bleed the brakes, but I'm not sure. Looking for some helpful insight. Thanks
    Dan
  • eyagel
    • Jan 2007
    • 756
    i would try to cleed the brakes, only if you know how..and then if that dosent work do the master cylnder, this happened to my friends e30 and he just kept driving it, i told him he was going to get into a wreck one time, but then a week later his motor chunked a rod, so yea
    • jms16v
      • Dec 2006
      • 314
      Thanks. That's pretty much what I was thinking.
      • rmousir
        • Nov 2007
        • 147
        I had the same experiance.. Master Cylinder.. Better check it. HTH
        Richard
        rmousir
        '87is work beater
        the RED BARON!
        RUNNING GREAT!
        After a $10.99 Intake Manifold Gasket.
        • Jparkr
          HR Admin
          • Jan 2006
          • 3494
          Richard
          X2 big x2
          if this happened randomly then its the MC. if it happened after you bled the brakes then i would say re-bleed
          1987 PRO-3 car /1990 325is (2.7i Concours)
          • jms16v
            • Dec 2006
            • 314
            Time to upgrade to a 25mm master cylinder!!
