How to properly bend brake hardlines?
  • erik325i
    • Jan 2005
    • 3567
    Is there a special tool/procedure to properly bend the hardlines for the brakes. I need to replace some of the brake lines and they do not come pre-bent from BMW. I want to make sure I no not kink the lines.
    Thanks,
    -Erik
  • SchnellerVert
    • Sep 2005
    • 3948
    With a brake line bender tool, it's cheap. Takes some practice.
    • E30SPDFRK
      • 5707
      Use your hands, just dont make the bends too hard.
      Byron
      Leichtbau
      • Jordan
        • 12916
        Said tool is available at most auto parts stores.
        Don't bend by hand... small adjustments to a bend sure, but don't do more than a few degrees by hand.
        https://mtechniqueabs.com/
        • SchnellerVert
          • Sep 2005
          • 3948
          Bending buy hand you will run out of line before you get to the proper finish point. The good thing is that line is cheap.
          • erik325i
            • Jan 2005
            • 3567
            Cool, thanks guys. I'll pick up one of those tools right away.
            -Erik
            • ultegra
              • Sep 2005
              • 20
              This is a recommended read:
              • erik325i
                • Jan 2005
                • 3567
                So, just as an update, I bought the correct brake line bender, and was actually able to bend up the lines to the correct shape first try. I installed them, and they fit great.
                -Erik
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  And for reference, this is what a bender looks like:
