Hey all,
Well I have been having a problem with my 1990 325i in which I removed the abs. It came time to bleeding brakes and the rears bled just fine and the pedal went to the floor as it should when the bleed screw was open. However, when pumping the brakes with the bleed screws closed and also when the FRONT bleed screws are open, the pedal doesn't go to the floor and hits a sort-of barrier. It sounds like metal on metal, not a pressurizing sound... I'm up for any suggestions! Thanks in advance
Max
Max
