Bushings - Urethane
  • Herb
    • 430
    Bushings - Urethane
    I have TH eyeballs, solid adj. subframe bushings, don't need rear swaybar bushings, and will soon have m3 swarbar end links (not sure what bushings I'll need there if any). I am running gc's with Billies. I need to replace ALL of the other bushings with urethane. It needs new control arms, so bushings for those too.
    Here is my list, please add/delete anything I am missing/don't need and suggest any company to use - PowerFlex, as of right now is what I will go with.
    1. Front Lower
    Wishbone Rear Bush
    2 per car (each) PFF5-301 1 15.95x2
    2. Front Anti Roll
    Bar Mounting
    2 per car (each) PFF5-302-19 2 19mm 12.95x2
    3. Rear Diff Mounting Bush 1 per car PFR5-300 19.95
    4. Rear Trailing Arm
    Outer & Inner Bush
    4 per car (each) PFR5-306 5 18.95x4
    Total = ~$153.55
    Thanks All
    Herbert
    bmpr stkr: real racers go left and right... so tru
  • Jordan
    • 12913
    Powerflex FTL.
    I'd recommend Irelands "race" bushings, or AKG's offerings.
    https://mtechniqueabs.com/
    • rs4pro3
      • 5808
      ditto on Ireland or AKG, I've got a mix of both on my car and have no complaints
      85 325e 2.7 ITB'd stroker
      • Herb
        • 430
        Thanks for the heads up. Other than PF ftl, should that be everything?
        • Jordan
          • 12913
          Subframe, trailing arm, and diff urethane will make the most difference. Sway bar bushings you really won't notice aside from a product of your stock ones being heavily deteriorated.
          • Herb
            • 430
            IE - Sway Bar Links - E30 M3 front adjustable links e30adjlink E30 M3 Adjustable Front Sway Bar Links $85.00
            IE - Rear Bushing Kit - urethane -E30,Z3, E36ti e30rearbush Rear Trailing Arm Urethane Bushing Kit -E30, Z3, E36ti $52.00
            - OR -
            AKG - Rear Trailing Arm Bushings Acentric (4)
            For BMW e30: 318 325 M3
            Polyurethane 75D with stainless steel sleeve
            Set includes thin wrench for simplified adjusting
            Cost $180.00
            AKG - Differential Mount Bushing
            Polyurethane 75D, with aluminum sleeve
            Cost $45.00
            The do just OEM swaybar bushings.
            • Jordan
              • 12913
              I can't recommend any of IE's hiem jointed swaybar links. Mine wore out into a clanky mess in less than 100 street driven miles.
              On my current e30 I will be giving it the THR eyeball arms, and AKG's full line of stiff urethane bushings.
              • StereoInstaller1
                GAS
                • 22679
                WTF dude, 100 miles? Shit joints or what? Did Jeff offer any solutions?
                So far I am 100% happy with all of AKGs stuff. Good service, too.
                Luke
                Closing SOON!
                Thanks for 10 years of fun!
                • Herb
                  • 430
                  Well I guess the question then, for the end links, is how much of a difference it will make using the regular mounting position with adj. links compaired to using the m3 position with adj. links.
                  • Herb
                    • 430
                    A little update...
                    Sway Bar Links - I might just use oem m3 links.
                    - OR -
                    Cost $180.00
                    Cost $45.00
                    Control arms and then just do OEM swaybar bushings.
                    Anyone see anything I'm am missing?
                    Herbert
                    • rcko
                      • Mar 2007
                      • 295
                      Highly recommend AKG. I replaced all the worned out rubber bushing on my 88 325is rear end with their urethane and am more that satisified. So far I have about 6k miles on them with no issues at all. When I rebuild the front end I will be using AKG offerings as well.
                      The only thing I see missing from your list are the subframe bushings and top shock mounts but I might of missed them while reading...
                      Another AKG product of that I used and been highly satisfied where their metal petal kit with the rubber inserts. It was a real nice touch to the interior of the cockpit...
                      - 0.05s and 0.1s FTW!!!
                      • gearheadE30
                        • Jun 2007
                        • 3734
                        Don't forget to pick up some urethane lube. It is different than other grease and it is generally 1-time application. Though poly bushings don't always leak, it's better to do it all the first time. My AKG offset CABs clunk badly, so I have to take them off again :(.
                        Something like this would do well.
                        Project M42 Turbo
                        • Nick325is
                          • 1409
                          I'm curious as to complaints about the powerflex. I have the race urethane subframe, diff, and trailing arm bushings and haven't had any real problems.
                          -Nick
