rear wheel bearing
  • Fuggly Stick
    • 79
    rear wheel bearing
    I'm going to change the rear wheel bearings myself soon. I have the b90 tool. Is there anything else I need? Any tips?
  • steinbachphoto
    • Aug 2007
    • 914
    i don't but question.
    where did you get your bearings? I need to replace mine as well
    http://www.steinbachphoto.ca
    • Garageaholic
      Freestyle Fabricator
      • Dec 2005
      • 5204
      Fag 'r' us.
      Sorry that was gay
      No pun intended
      go to www.bmaparts.com
      Recent Rebranding!!
      E30 SM62/S62
      E30 M60 V8
      E30 M30 Big 6!
      Instagram.com/garageaholic
      Youtube.com/garageaholic
      • FredK
        • 14763
        With the B90 tool, this job is a lot easier. Don't forget to use some antiseize or other high pressure assembly lube while pressing the new bushings in. I'm finshing up my bearing job. All I have left is to install the hubs.
        • e30sd
          Fistee
          • Jan 2004
          • 5517
          WRONG dont use any lube on the bearing, just make sure the pocket is clean as a whistle. the only thing you should be lubing is the threads on the b90 tool.
          • FredK
            • 14763
            Are there any specific reasons not to use assembly paste? I was using a can of stuff that specified it was meant to ease press fits.
