More Brake problems!!!
  • 02stu
    • Jan 2005
    • 872
    Thanks for everyones help on the ABS problem. It turned out I didn't have the ABS pump powered correctly. However I still do not have very powerfull brakes at all. They are much worse then my 95 Suburban. Does this sound like a booster problem or could it still be the ABS pump? I am going to VIR in a month so I need to get this solved ASAP. Thanks again for your help, this one really has me stumped.
  • Mike B.
    • Jan 2006
    • 987
    I don't recall, what booster are you running with your swap? What size master?
    • 02stu
      • Jan 2005
      • 872
      I am running a e21 320i booster
      • Mike B.
        • Jan 2006
        • 987
        I had an e21 booster on one of my swaps with the stock master. I would describe the pedal feel as vague at best.
        They performed adequately on the street and the track.
        When you say underpowered, could you be a bit more specific with the feeling you have when you press the brakes?
        • AndrewBird
          The Mad Scientist
          • 11898
          Stock master cylinder?
          • e30evolution
            West Werks
            • 1888
            The brake master cylinder has an o ring on it that seals vacuum inside the booster.... if it is leaking there your brakes will suck
            http://www.westwerksauto.com
            • 02stu
              • Jan 2005
              • 872
              yep, stock.
              The booster is holding vacuum, I took the hose off today to check the one way valve on the hose and the booster was still under vacuum with the car off.
              • Massive Lee
                • Sep 2006
                • 6785
                Hi 02stu
                Are you using old pads on new discs (or vice-versa)? Did you change anything with the brakes? Did you open the lines to the air (bubbles)?
                massivebrakes.com
                • submwar
                  • 216
                  air bubbles will give you that inconsistent pedal feel
                  check out those seals they might be toast
                  • 1990m3
                    • 1180
                    sounds like air in the line to me. I've also had problems with Hawk pads requiring me to pump the pedal one full time before any braking actually started to work. Switched out to different pads and the problem went away. I still don't get that one.
                    • emi325i
                      • Oct 2006
                      • 356
                      Ha.. I knew I wasn't the only one that had problems with hawk pads. Those pads were scary no matter what car I put them on. I noticed they don't bite until warm. That makes for very scary winter driving.
