"Brake Lining" Warning Light
  • kencopperwheat
    King of Kegstands
    • 14396
    Is there a sensor for the parking brake shoes? My pads and sensors are brand new and the light came back on. I only ask if it's the parking brake b/c when I have it on the "parking brake" light doesn't illuminate.
    Originally posted by Gruelius
  • erik325i
    • Jan 2005
    • 3567
    No, there's no sensor in the shoes. You may have a broken wire somewhere on the wear sensor.
    -Erik
    • Van Westervelt
      • 9365
      One of them is either bad, or just got inserted badly. x2 on No ebrake sensor. My assumption it that its your rear wires, as your ebrake cable runs near it.
      • Garageaholic
        Freestyle Fabricator
        • Dec 2005
        • 5204
        Just a shot in the dark,
        Pin 15 on the C101 port goes from Pin 85 on the unloader relay K5 all the way to the starter as a temporary ground. I know that nothing has changed on the starter since you changed the brakes, but it's a good check to make sure that you have that proper ground on the starter.
        Recent Rebranding!!
        E30 SM62/S62
        E30 M60 V8
        E30 M30 Big 6!
        Instagram.com/garageaholic
        Youtube.com/garageaholic
