Problems with positive rear camber.
  • Coouuper S
    • 141
    Hey folks, how is everybody doing....
    I bought this car this way with some markings on the rear valance and tire so I know the wheel got hit on a curb or something. It's time to fix it but I would like to know if you guys would know what the problem could be. Visually I can not see the subframe, trailing arm, or wheel hub being bent or etc. What do you guys think is the problem here ? Sorry for the bad pictures but this is all I got now.
    As you could see, the right E30 has some positive rear wheel camber.
    I am thinking about the trailing arm but any help would be great before I start tearing it apart.
  • AlarmedBread
    • Sep 2006
    • 1510
    you're right, something is obviously bent. probably the trailing arm, but the subframe tabs could also be damaged.
    • Coouuper S
      • 141
      Would a slight bent trailing arm show ?? The tabs and trailing arm look just fine.
      I will be taking it apart anyway next weekend or so but any other thoughts would be greatly appreciated.
      • golde30
        • 11464
        trailing arm + possible subrame damage would be my guess also.
        IG: @Baye30
