Too much stopping power on front...
  • diegom6
    • 4447
    Originally posted by Massive Lee
    This is the fixed pressure limiting valve.
    So I remove it completly? Or do I dissamble it and take off the restrcictor isnide (if it has one) of it and bolt the body back in to those lines?
    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
    • diegom6
      • 4447
      • Massive Lee
        • Sep 2006
        • 6785
        Why don't you just make a hard line with female ends with the same overall length as the limiting valve? Or have a local shop make a braided line for you?
        massivebrakes.com
        • diegom6
          • 4447
          Didn't had a chance to take it off yet while I was asking here to be sure hehe...I'm going to remvoe it now.
          Thanks
          • Fidhle007
            I can fly, motherfucker
            • Oct 2005
            • 7209
            Do all year cars have this?
            '89 325is S50 Track Montser
            '04 X5 Daily/Tow Vehicle
            http://www.avarestoration.com
            http://www.myspace.com/brendanfiddle
            Click here if you want to be my zombie slave...
            http://www.youtube.com/user/Fidhle007
            • Massive Lee
              • Sep 2006
              • 6785
              All cars with front and rear disc brakes have it AFAIK.
              Removing it will add a bit of rear bias under high hydraulic pressure, but it will not fix oversized front pistons. Many suppliers found on eBay will sell front calipers with 1.75" pistons only because they are cheaper than 1.38" ones...
              Lee
              massivebrakes.com
              • Fidhle007
                • Oct 2005
                • 7209
                This is good news though because that answers my bias issue that I've been having since I removed my failing ABS pump, front wheel lockup was way easier than I wanted. I have a Tilton adjustable proportioning valve that I bought when I removed the ABS but I've had no reason to install it because of the heavy front bias. I'd much rather have a more 50/50-ish bias with the option to reduce the rear than my inside front wheel flat-spotting three to four times a day on my daily commute... :-)
