i am swapping the full suspension off a e36 m3 and it has 355mm 2 piece rotors and 4 piston brembo calipers. i know it will all bolt on but i don't want to run 18s that are needed to clear them.
my question is can i buy different carriers and use stock size, cross drilled m3 rotors with the fancy 4 piston brembo calipers so i can just run some 17s?
if its at all possible, then i'm sure its been done before. so which carrier would i need?
