E30 caliper compatibility
  • BigD
    • Jul 2006
    • 1085
    Hey guys,
    So back in the winter, I snapped a bleed screw on my right front caliper while preparing to move my swap car. It was not a big deal then and I got a used caliper from a fellor r3ver for a 6" sub.
    I went to install it yesterday (doing all new soft lines, pads and rotors) and to my horror the calipers were different. The one I got has Honda style floating pins, which bolt into the outer edges of the caliper and float in the carrier. Mine has a design like the E34, with pins bolting into the carrier and the caliper floating on them.
    A friend of mine saved my ass by giving me a complete caliper with the carrier, but it was also the other style. Thankfully the carrier bolt pattern is the same so it fit.
    My question is, is there any difference in clamping force or anything else that could make them incompatible somehow? I don't want to have to find out the hard way by having my car pull to the side on a racetrack...
  • PiercedE30
    • Apr 2005
    • 4220
    Sounds like the calipers currently on your car are the Girlings and somebody gave you an ATE caliper. Ate>Girling
    My 2.9L Build!
    • BigD
      • Jul 2006
      • 1085
      Yeah, my old ones say Girling. Are they about equivalent though? Should I make it a priority to swap out the other side too?
      Thanks.
      • DCColegrove
        • 2748
        Not a good idea to mix them.
        I would recommend the Girlings over the ATEs though, there is a good reason BMW switched.
        • Massive Lee
          • Sep 2006
          • 6785
          The Ate calipers are better than the Girling ones. They are stiffer and have a better pin system. Many here have swapped their Girlings for ATEs and have reported a much better pedal feel. Obviously they should be replaced in pair.
          Had I known... I dumped three sets of very good condition Girlings last week.
          massivebrakes.com
          • BigD
            • Jul 2006
            • 1085
            Sorry my old calipers are actually ATE, the girling ones are the ones with the Honda-like pin design, the replacement one I got. Alright, I'll see about finding one.
            • Schneider325
              • May 2004
              • 3818
              ATE all around, or just the rear?
