Master cylinder rebuild kits?
  • zedfez
    • Jun 2008
    • 67
    Does anyone make a master cylinder rebuild kit for the 325iX? If not, and I am replacing it anyways, should I replace it with a stock rebuilt M.C. or is there a better one to use. I have heard of people using the cylinders out of 5 series and 7 series. Thanks.
  • NC325iC
    • Mar 2004
    • 6565
    just replace it, if you want info on a non stock option, search for 25mm mc
    • Jonsku
      • Oct 2004
      • 566
      For example 750 master cylinder (25mm) is straight swap..
      - E34 M5 (x 2) -
      - E30 V8 Cabrio "Kylpyamme" -
      - Alpina D10 Touring #33/94 -
      - E46 318i Touring -
      - Toyota Hiace 4wd -
      • 2002maniac
        • 4260
        dont do the 25mm cylinder with stock brakes. terrible. if you absolutely need a stiffer pedal the e30 M3 cylinder is as large as you should go.
        to answer the OP's question I have not seen seal kits for some time.
