does anyone experience caliper flex under pressure of it (braking) ? While we were blidding the brake lines with out the wheels mounted in the front I did notice the caliper will flex "quite alot" but from the outder side of it basically, this kinda scare me a bit.
While I was talking to a fried who has a heavily Impreza GT modded, he run full Wilwood (front and rears) BBK with 6 piston in front and 4 piston on the rear he was like "uh..dunno, let's check mine) and so did the same as mine, the 6 piston caliper did flex some just as my Superlites 4 piston calipers and he was kinda shocked with that.
Oh, if you are reading this Lee, the noise I talked to you about, are defentetly from the pistons itself, while making the oise (with out the wheel mounted) I added some brake fluid to the pistons and the noise went away right there. So it wasn't the pad compound.
-Diego
PS: Did my friend send you the money for the Q pads?
-Diego
