I searched, I promise.
I cannot get the CV axles back into the hubs. I tried all the suggestions that I found during search.
- I tried turning the hub one set of teeth. No luck.
- I tried wire brushing the inside of the hub and the splines on the CV axle. No luck.
- I tried Liquid Wrench on the splines. They just laughed at me.
- I tried tapping on the CV axle. No luck. I hammered harder and seperated a brand new wheel bearing.
- I tried welding an axle nut to a piece of pipe and turning it down on a lathe to make a puller similar to the BMW special tool. The weld broke.
The splines engage about 1/16 of an inch and stop. I am out of ideas. What is the magic trick to get these two together?
This works well.
