First Shakedown event was this past weekend. Went out to an autocross after months of restoration and prep work on this E30. It still needs a some work and some sorting out, but is 90% there. Will be addressing swaybars (currently none are attached), and getting the exhaust done up.
In testing I found that the ABS doesn't appear to be working!!! It was quite easy to lock up the brakes. The tires are 3 year old beaten Hankook RS2's so their lack of grip (they are quite hard) should have made the abs prevalent frequently.
*worst example of lock-up from the weekend.
I'm looking for insight on testing the abs pump or what I can do to diagnose this issue. It wasn't excessive like in the above picture, but it was an issue. I couldn't attack like I normally would in ABS equipped cars. I'm hopeful that I can resolve this as I'd like the car to have ABS.
All brake calipers and rotors were replaced, stainless brake lines were installed in place of the rubber lines, and Axxis Ultimate brake pads were put on all four corners.
I did some searching on here, but most threads were about the ABS light being on (which it isn't) and the relay under the dash or other culprit that would throw an ABS light.
All input greatly appreciated.
Thanks - Jon
Thanks - Jon
