Yeah those arms are form a guy in s14.net and thay are basically clones of the gen1 e30 m3 dtm rear arms. They arent finished yet and the inner joint was replaced with a heim. its independently adjustable for camber and toe without changing roll center on the outboard mount. The guy has a subframe too that has the built in roll center adjustment on the outer pick up and it was also modded to fit an e39m5/e46m3 diff and to use the m5 drive shafts.
in the front the arms are adjustable for track, camber(resumable with the strut tops), caster, dive(anti or pro), bump steer(adjustable tie rods) and roll center(with spacers). The rear pickups are reinforces with a third mounting point and the inner ball joint was recessed into the subframe an mounted in double shear.
With a nice set of moton or ohlin dampers this is probably the ultimate e30 suspension. Zero friction joints and tons of ajustability. only way to improve would be to ditch the rear trailing arm setup for something else crazy
