Weird sound after New brakes installed
  • EvoStevo
    • 173
    Hey guys, I just did brakes for the first time this past weekend. Everything went smoothly and the brakes were working fine until yesterday. Under relatively hard braking I can hear a knocking sound which seems to be coming from the passenger side, possibly the rear. The frequency of the knocking seems to be relative to the speed at which I am stopping. So when I'm stopping from 50-0, the knocking sound is faster than if I'm stopping from 35-0. Any ideas what it could be?
  • Massive Lee
    • Sep 2006
    • 6782
    Jack your car and perform an inspection before a caliper falls...
    massivebrakes.com
    • FreedS4
      • 752
      I'm having a similar issue now after my recent pad/rotor install. Any ideas what it could be? Thanks in advance.
      Chris
      • vtman05
        • 86
        Did you guys bed the pads, are the rotors new? Definitely get under there and make sure your pistons are not on the verge of seizing.
        • FreedS4
          • 752
          Yes, new pads/rotors and the noise started as I began to bed the pads. How does one go about checking to see if they're on the verge of seizing?
          Chris
          • FreedS4
            • 752
            So I've still got this issue. I went ahead and put in new control arms and M3 CABs, still nothing. I swapped the pads from the passenger's side to the driver's side to see if that was the issue and nothing changed. Any ideas?
            Chris
