Help!! Stripped bolt!
  • 30secE30
    • Nov 2008
    • 100
    ok im trying to change my front brakes and i freaken stripped out the bolt that holds on the caliper then i drilled it and still not coming out what should i do i really dont want to change the wheel bearing hub. any suggestions?:(
    1990 325i BMW
  • e30serg
    • Dec 2006
    • 562
    Get a torch and heat it up. Use an ez-out afterwards. I bet you the PO used loctite when he re-installed it instead of getting a new bolt, like he should have done.
    • bmwpower
      • 1556
      Which bolt is it? The guide bolt or the carrier bolt?
      89 325is track project / 05 x5 / 99 M3
      E30 stuff for sale | Parts I'm looking for
