Subframe Removal... I know but I dont understand the other thread
  • thereisnoyun
    • Feb 2007
    • 2301
    So I got everything disconnected. The big nut is out, I hammered it out from the top. I took off both plates. trailing arm is the only thing left, but are parallel and on jack stands.
    The subframe isnt coming off. I am assuming the bushing is getting caught. Now the question is. where do I apply the leverage and waht tool to break it lose. Thanks.
  • MDryVur
    • 395
    you took the rack and pinion off right... lol
    • thereisnoyun
      • Feb 2007
      • 2301
      yea my bad. REAR SUBFRAME. I took the two holding plate off, the two 22mm nut, and the actual bolt from the undeneath the rear seat. I unbotl all the break mechanism and took out the ebrake line. Nothing is connected. But it wouldnt come out.
      • FredK
        • 14763
        this is how I did it:
        • MDryVur
          • 395
          rusted shut huh.... wd-40 alot of it.. lol
          • abepark
            • Feb 2006
            • 384
            genius. I was thinking i had to remove the whole back end to do these. Where do the subframe bolts come up into the body? under the rear seats? or in the trunk?
            • MDryVur
              • 395
              Originally posted by FredK
              dude.. that's awesome :nice:
              • FredK
                • 14763
                Under the rear seat. You just have to pull the bottom cushion out.
                • 2002maniac
                  • 4260
                  Just pray the aluminum doesnt break off inside. I had to get mine out with a die grinder and chisel. :(
                  • xLibelle
                    • Aug 2004
                    • 2673
                    that is likely the most common case for ease of removal, due to the required forces not being of easy access. I tried pry bar above subframe and below body but you bend metal that way.
                    Tried multiple ways and ended up shaking the diff and adding force with lever. Ends broke anyhow.
                    They are not hard to get out. Big drill bit and a chisel for the rest of it, if theres anything left. Once the bit gets in a certain depth, the rest breaks free.
                    • asubimmer
                      • 6482
                      thats the best way to do it. I have a lag bolt in the toolbox now. I also have a spare subframe bolt to use in the top to pound it out. 2/3 hits and you are a free man.
                      • thereisnoyun
                        • Feb 2007
                        • 2301
                        yep, this worked like a charm. One hit from a 4 lb hammer and the subframe broke loose.
                        • Kingb
                          • 928
                          When I had all the bolts out I took a punch the size of the bolt and put it up in the bushing and hit it from side to side until it wiggled and came loose. Prying didn't work for me but this did.
                          Originally posted by Nicademus
                          My car beats off to that car. :bow:
