High-speed braking problem
  • Mystikal
    Wheel Fitment Expert
    • 9602
    Have a rather unsettling braking problem that only happens from very high speeds, i.e. 110mph+. Starting a few months back, I was getting a very bad vibration, which I attributed to warped rotors and completely gone wheel bearings. I replaced them, and at sane speeds everything is perfect. However, if I am slowing down moderately or harder from very high speed, by the time I get down to about 60mph, the front brakes begin to make a grinding noise (almost sounds like a completely worn down pad) and braking performance fades away to about 50% of what it started out as. I'm thinking maybe it's the pads, but I'm not too sure.
    This is the current setup:
    Front: Brembo O.E., Pagid non-sport
    Rear: Whatever the dealer puts (not my work)
    Any thoughts? I'm going with EBC Greens next spring, but just wondering if there could be another source.
  • spencers
    • Jan 2004
    • 1150
    Man. I have the same problem!
    I get vibration from any braking! However I'm not sure of my problem..
    • Mystikal
      • 9602
      Um, I don't have any sort of vibration, read it again. And you probably just have warped rotors.
      • Jordan
        • 12916
        Yeah, I have a similar problem. Only occurs at high speeds. Yesterday it happened when I dropped anchor from 120 down to 60 for a slow truck. My rotors are definately warped, but when I'm being nice on them they dont shake. For a couple minutes after that they were shaking under any braking tho.
        https://mtechniqueabs.com/
        • Rob
          • 8166
          sounds like glazed pads to me.
          BEERTECH
          • BMW BMXER
            • 2325
            I agree, my brakes used to do that, I swapped my pads its stopped. I posted about it a long time ago.
            Sold it.
            • rwh11385
              lance_entities
              • 18403
              Sorta an issue for me as well. reducing velocity at a quick rate will have car shimmy a little bit. However, I am still impressed with the braking power.
              How do pads get glazed?
              • Mystikal
                • 9602
                Good, I'm happy it's the pads. It's really not any sort of shimmy or vibration, just a horrible grinding noise and poor stopping ability. I probably won't be going over 180km/h until winter is over, so I'll put off changing the pads until spring.
                Thanks guys.
                • Rob
                  • 8166
                  glazed pads is sort of a quick overheating of the pad
                  BEERTECH
                  • Mystikal
                    • 9602
                    That is exactly the description I would come up with. Once they get about 10 seconds of cooling, they go back to normal until the next long braking session. These pads would kill me on a track (something I plan on doing next year). Luckily our auto-x is extremely low-speed, I can still run that on these pieces of shit. Noisy, dusty, plus they can't take heat.
                    • Axxe
                      • Aug 2004
                      • 3355
                      I get a vibration in the steering wheel @ 140km/h, and it stops at 160ish. Warped rotors or wheels out of balance? I'll have to see what happens after I put my winters on in December.
                      Keep it slideways!!
                      • Rob
                        • 8166
                        warped rotors usually cause vibration under braking, since they're a part of the brake system... your problem sounds like the wheels need balancing
                        BEERTECH
                        • clavinZERO
                          Hella sick E30
                          • Mar 2004
                          • 2027
                          Check your bushings and ball joints as well. make sure the whole front is tight as that can also make things vibrate. Your pads sound like they are toast.
                          "BMW Style 32 Poster-Child"
                          HTTP://WWW.CLAVINZERO.COM/e30-5-lug
                          **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
                          • rwh11385
                            lance_entities
                            • 18403
                            I've come to the conclusion my loose driver side CA bushing is to blame in part for some wobble perhaps.....if that isn't too extreme of a word to use.
                            So yeah, check the bushings.
                            • Mystikal
                              • 9602
                              Thanks for the suggestions, but for the last time, I have no sort of vibration. And if it were those, it would be causing issues immediately when I throw the anchor.
