Alignment questions
  • bimmers4life
    • 420
    Alignment questions
    I am picking up new wheels and tires tonight and want to get my car aligned on sunday. My question is if i get it aligned and then 2 weeks from now replace my control arms, will that throw my alignment off? Thanks
    Richard
  • Liam
    • 753
    It could somewhat, I would recommend doing it all at once just on general principals.
    I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
    • daniel
      • 6703
      do it all at once and save some money.
      http://instagram.com/dslovn.drives
      • Madhatter
        • Oct 2004
        • 966
        camber (and more likely) castor will change when you replace the arms, so it will probably throw the toe out, so as said above, wait.
        Unless you have a really, really bad alignment, you should be able to survive two weeks on new tyres without doing any significant damage to them.
        Just a little project im working on
        - http://www.lse30.com -
