Massive BBK Wheel Fitment Guide
  • Emre
    • Sep 2007
    • 1228
    Originally posted by Massive Lee
    Bimmerworld now sells the Pro Race 1.2 I believe...Then there's the 1.3 which seems to offer great BBK compatibility.
    The 1.3 looks interesting. Both lighter and cheaper than the 1.2 from what I can tell. Have you been able to test one of these yet?
    My kit barely clears the Bimmerworld 1.2 wheels using 11.75" rotors and your old Outlaw 4000 calipers (outside radius = 168.7mm), which have very slightly better clearance than the Wilwood Forged Billet Superlight (outside radius = 169.9mm).
    If the 1.3 wheels have any less room than the 1.2's, it would make for a pretty tight fit.
    1987 Mercedes 190E 2.3-16: Vintage Racer
    2010 BMW (E90) 335xi sedan: Grocery Getter
    • Emre
      • Sep 2007
      • 1228
      Here are some pics. Outlaw 400 calipers with 11.75" diameter 0.81" thick rotors. Wheels are TDR Pro Race 1.2 in 15x7" ET25 no spacers.
      Very tight fit.
      • Massive Lee
        • Sep 2006
        • 6785
        I was reported from Matthew in Canada that the 280mm kit fits Ronal's ACT LC wheels very well. Another win for the Street kit... Don't be fooled by its name, it's also a track kit with the appropriate B compound pads.
        massivebrakes.com
        • maniacmatt
          • Feb 2007
          • 483
          This is correct. This kit is awesome. Pics to follow tonight.
          • SkinnyVT
            • Nov 2008
            • 391
            Sport kit fits with Team Dynamics 1.2's. Tons of room behind the spokes but it is close around the barrel of the wheel.
            '86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
            • Massive Lee
              • Sep 2006
              • 6785
              Hey Jeff
              There's no problem with shaving a few mm off the tips of the calipers, where they are cose to the rim. These are totally non-structural areas.
              Lee
              massivebrakes.com
              • stormspike
                • 401
                Will they fit?
                Any idea if the Big Brake Kit will fit the following? This is the 4 lug setup 16"
                • SkinnyVT
                  • Nov 2008
                  • 391
                  Hey Jeff
                  Lee
                  I ground them down a little bit more after I took this picture. There is about a 1" section of the barrel right by the spokes that is a smaller diameter, I think with the spacers it will push the wheel out just enough to where the caliper will clear that section
                  • SkinnyVT
                    • Nov 2008
                    • 391
                    print out the template and check. http://www.massivebrakes.com/kits/e3...300/21/318-325
                    btw, there are 3 different kits.
                    • maniacmatt
                      • Feb 2007
                      • 483
                      Late but as promised pictures of street kit fitment with Ronal LS 15x7.5 et25 I am running one of Lee's 3mm spacers also for tire to strut clearance.
                      • JRKOUPE
                        • Dec 2004
                        • 3159
                        thnx for the pics!!!!!....
                        .is the spacer on in the pic where the tire appearsrightnexttothestrtube?...maybe you should go w/ a 5mm for deflection under hard track use.
                        • maniacmatt
                          • Feb 2007
                          • 483
                          Ya thats with the spacer, the picture is sort of an allusion though. There is more room than it appears in that picture.
                          • SkinnyVT
                            • Nov 2008
                            • 391
                            Just did a very quick check with the TRM 15x8's over the Massive Sport kit. They would require significant grinding of the corner of the caliper for them to clear the barrel. Didn't get it seated on the hub to check spoke clearance.
                            • Massive Lee
                              • Sep 2006
                              • 6785
                              That's what I thought about the TRM. I guess they are good wheels, and affordable, but not really designed toward BBKs like some other track wheels are.
                              massivebrakes.com
                              • mdv
                                • 61
                                Installed the street kit this weekend.
                                Fits Kosei K1's 15X7 et27 no problem.
                                Also fits Borbet Type H 15X7 et 45 without issues.
