No, the 300x32mm. Im pretty sure the 300x21 would almost fit with no spacer. If anything id say it would for sure with a 3mm spacer tossed in.
Massive BBK Wheel Fitment Guide
On top of the bigger diameter of the rotor and caliper, you must also factor-in the extra thickness of the caliper. Therefore, because the wheel is 17", it will not necessarely mean it will clear the caliper behind the spokes. If you don't have the wheels with you, perhaps you can send the profile and ask the seller to check for you. Also, remember that wheels with wide lips will have the spokes pushed more inward, offering less clearance for calipers.
massivebrakes.com
A member generously sent me two pictures showing the test fitting of the 280mm kit template with a 15x7 D Force wheel. He says it works just fine with plenty of room to spare.
Thanks very much Levent
massivebrakes.com
Update here:
same wheel as above, Dforce LTW5
i did the 300mm kit profile last night and it fits. will post pics of spoke clearance later today. i would say clearance at the spokes is about 3mm or so, so a 3mm spacer might help with peace of mind (and any discrepancies due to paper curve)
edit:as promised pics of caliper-spoke clearance
Last edited by NC325iC; 02-10-2010, 02:55 PM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.Comment
I would definitely be in for a 332mm kit, we should get a group buy going... Is this still a possibility?However, if Lee were to make a 332mm kit, this would most likely move the caliper up approx 16mm which I think would make the fitment of the bigger rotor possible.
If anyone would be interested in a 332mm kit for 4 bolt e30's to fit under the 17's please let me know. I currently have a 310mm kit from another vendor with a 32mm rotor and I do see fade when mountain driving. Plus a 332mm kit just looks proper under larger wheels. Lee has mentioned in order to produce the kit he will require 5 people interested in a group buy.sigpicComment
Not really a GB, more a killer intro deal.
massivebrakes.com
Wow, I didn't see that! Ugh, hopefully I'll have that much money before Mar. 1, stupid college sucking up all my money... :(Not really a GB, more a killer intro deal.
http://www.r3vlimited.com/board/show...99#post1868899sigpicComment
Has anyone tried fitting the 15x8 or 15x9 6UL wheel from 949 Racing? I am in the market for another set of rims to complement my 15x7 Pro Race 1.2 but would like to leave the option for one of Massive Lee's BBKs since I'm putting in an S52.
Apologies if this has been asked before but I went through the thread and searched the rest of the forum; it appears that the 6UL wheels aren't too popular here?
-Erniesigpic
1990 325iComment
you are right..its not that common here...but I do like it.Has anyone tried fitting the 15x8 or 15x9 6UL wheel from 949 Racing? I am in the market for another set of rims to complement my 15x7 Pro Race 1.2 but would like to leave the option for one of Massive Lee's BBKs since I'm putting in an S52.
-ErnieI love sitting down and just driving!Comment
Nope, mainly because of the requirement of big spacers and only a few street tires in appropriate sizes.Has anyone tried fitting the 15x8 or 15x9 6UL wheel from 949 Racing? I am in the market for another set of rims to complement my 15x7 Pro Race 1.2 but would like to leave the option for one of Massive Lee's BBKs since I'm putting in an S52.
-Ernie
The 15x9s require 4x100 to 4x100 adapters thanks to the offset that needs to be overcome.
I was seriously considering the 15x8s a couple of months ago.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
So did you mean that no one has tried it or that they won't fit over the brakes?
But you do have a good point there. I only saw one street tire that I would want to fit the 15x8 (the Hankook RS3s) ...good tires nonetheless, but an indication that I might have problems later finding tires.
I like the APEX ARC-8s (17x8 4x100) but I was hoping to save the cash. The BBS RG-Fs in the first post are gorgeous but they're only 7" wide and blow my budget out of the water. Oh well...the search continues...
I'm curious...what wheels did you end up going with that were wide enough for meaty rubber and fit a BBK?sigpic
1990 325iComment
