Massive BBK Wheel Fitment Guide
  • qbuilt
    • Jun 2007
    • 94
    #106
    No, the 300x32mm. Im pretty sure the 300x21 would almost fit with no spacer. If anything id say it would for sure with a 3mm spacer tossed in.
    • Brian D
      • Mar 2006
      • 832
      #107
      OK cool, thanks for the clarification.
      1973 Bavaria
      • E30QC
        • 214
        #108
        do any of the eurostop wheels fit?
        • mazur
          • Jan 2006
          • 731
          #109
          What do you guys think about the XXR 006's in 17x9 trim when it comes to clearancing the Race Kit?
          Intuitively I'm thinking any wheel that big should clear almost anything, but I'm a noob to BBK fitment.
          • Massive Lee
            • Sep 2006
            • 6785
            #110
            On top of the bigger diameter of the rotor and caliper, you must also factor-in the extra thickness of the caliper. Therefore, because the wheel is 17", it will not necessarely mean it will clear the caliper behind the spokes. If you don't have the wheels with you, perhaps you can send the profile and ask the seller to check for you. Also, remember that wheels with wide lips will have the spokes pushed more inward, offering less clearance for calipers.
            massivebrakes.com
            • mazur
              • Jan 2006
              • 731
              #111
              Yah, I was thinking the same. It might end up being that a larger offset would have to be ordered so that using a wheel spacer would give you added clearance.
              Thanks for the response Lee.
              • Massive Lee
                • Sep 2006
                • 6785
                #112
                A member generously sent me two pictures showing the test fitting of the 280mm kit template with a 15x7 D Force wheel. He says it works just fine with plenty of room to spare.
                Thanks very much Levent
                massivebrakes.com
                • NC325iC
                  • Mar 2004
                  • 6565
                  #113
                  Update here:
                  same wheel as above, Dforce LTW5
                  i did the 300mm kit profile last night and it fits. will post pics of spoke clearance later today. i would say clearance at the spokes is about 3mm or so, so a 3mm spacer might help with peace of mind (and any discrepancies due to paper curve)
                  edit:as promised pics of caliper-spoke clearance
                  • 91greg325i
                    • 387
                    #114
                    Originally posted by qbuilt
                    However, if Lee were to make a 332mm kit, this would most likely move the caliper up approx 16mm which I think would make the fitment of the bigger rotor possible.
                    If anyone would be interested in a 332mm kit for 4 bolt e30's to fit under the 17's please let me know. I currently have a 310mm kit from another vendor with a 32mm rotor and I do see fade when mountain driving. Plus a 332mm kit just looks proper under larger wheels. Lee has mentioned in order to produce the kit he will require 5 people interested in a group buy.
                    I would definitely be in for a 332mm kit, we should get a group buy going... Is this still a possibility?
                    • Massive Lee
                      • Sep 2006
                      • 6785
                      #115
                      Not really a GB, more a killer intro deal.
                      massivebrakes.com
                      • 91greg325i
                        • 387
                        #116
                        http://www.r3vlimited.com/board/show...99#post1868899
                        Wow, I didn't see that! Ugh, hopefully I'll have that much money before Mar. 1, stupid college sucking up all my money... :(
                        • eandrade
                          • Jan 2007
                          • 117
                          #117
                          Has anyone tried fitting the 15x8 or 15x9 6UL wheel from 949 Racing? I am in the market for another set of rims to complement my 15x7 Pro Race 1.2 but would like to leave the option for one of Massive Lee's BBKs since I'm putting in an S52.
                          Apologies if this has been asked before but I went through the thread and searched the rest of the forum; it appears that the 6UL wheels aren't too popular here?
                          -Ernie
                          1990 325i
                          • JRKOUPE
                            • Dec 2004
                            • 3159
                            #118
                            -Ernie
                            you are right..its not that common here...but I do like it.
                            • z31maniac
                              • 17566
                              #119
                              -Ernie
                              Nope, mainly because of the requirement of big spacers and only a few street tires in appropriate sizes.
                              The 15x9s require 4x100 to 4x100 adapters thanks to the offset that needs to be overcome.
                              I was seriously considering the 15x8s a couple of months ago.
                              www.gutenparts.com
                              • eandrade
                                • Jan 2007
                                • 117
                                #120
                                So did you mean that no one has tried it or that they won't fit over the brakes?
                                But you do have a good point there. I only saw one street tire that I would want to fit the 15x8 (the Hankook RS3s) ...good tires nonetheless, but an indication that I might have problems later finding tires.
                                I like the APEX ARC-8s (17x8 4x100) but I was hoping to save the cash. The BBS RG-Fs in the first post are gorgeous but they're only 7" wide and blow my budget out of the water. Oh well...the search continues...
                                I'm curious...what wheels did you end up going with that were wide enough for meaty rubber and fit a BBK?
                                1990 325i
