RTAB Poly Bushing Fitment Question
  • gilber33
    • Jul 2012
    • 244
    I have the rear subframe pulled and I installed Revshift poly RTABs. The metal sleeve is like 1/16th of an inch longer than the bushings. When I installed the bushings into the subframe, I noticed that the bushings sit flush against the bracket on the subframe and because the metal sleeve is just a big longer than the bushings, this created a small gap betweent he edge of the trailing arm and the lip on the bushing. See the pictures below. Is this an issue? To me it makes it look like the trailing arm now has room to move side to side. I would have assumed that the bushing installed in the trailing arm would be flush with the sides of the bracket and the traling arm.
