~87 325is brakes on 85 318i?
  • Spaz!
    • 157
    Can anyone tell me what parts I would need to do this swap? My old 325is had all the brakes I needed but the 318i I picked up leaves something to be desired in the braking department.
    Or, is there a similar setup that would be a better option? I may try my hand at autocross at some point but this cars primary use is just to go drive the mountain roads on the weekends.
    TIA, Jon
    '82 633CSi (euro) Jaws!
    '84 318i, project?
    '05 745li, DD when it wants to be...
    '87 Corolla FX16, old faithful
    '89 V1500 Suburban, GP rig
    '69 Columbia 36 MkI, retirement home.
  • Spaz!
    • 157
    I may swap in my 325's mildly built m20b25 at some point but for now the plan is to get the M10 running properly and maybe turbo charge it to see how I like it.
    '84 318i, project?
    • Holland
      • Nov 2008
      • 7212
      You need to swap over the entire trailing arm and everything attached to it. Brake bias will be a little off but will work fine.
      Originally posted by DEV0 E30
      • Spaz!
        • 157
        Thanks Holland! Are the fronts the same? They sure look tiny but it's been a while since I wrecked my 325.
        BTW nice avatar, my Columbia is registered as Gekkou.
        '84 318i, project?
