Hey guys I made a mistake my brake/clutch reservoir was low I stopped at a gas station a purchased dot3 brake fluid instead of dot 4.:(
now my right rear brakes are now squeaking and the anti lock light came on for the first time for 5 seconds. That light has never come on since I have owned the car.
I have read some articles saying basically that you can add higher dot rating then recommended but never lower.
What should my next step be?
remove all the fluid in the reservoir with a turkey baster add dot 4 fluid and bleed the brakes?
This occurred on sat I drove it home and haven't moved it since.
Yes it was my mistake I don't need to be reminded of it. just need a solution.
