Please help me
  • Mkcustoms88
    • Mar 2015
    • 56
    Please help me
    Trying to remove rear axle nut , God dam rust is there any tricks or helpful hints , thanks
  • roguetoaster
    Biggus Tippus
    • 7829
    First, make sure the whole assembly isn't rotating when you are working and remember that the locking plate may be in the way, it should be around the base/perimeter of the nut. Try to pry it away.
    Second, this is where you really want an impact wrench as they are adept at removing stuck fasteners.
    As a last resort you can use heat/cold to help stuff along, but you may kill your wheel bearing seal.
    If all else fails you'll need an air chisel to finish the job.
    • Mkcustoms88
      • Mar 2015
      • 56
      Ok thanks, gonna give this a try
