Lowering springs are noisy and rough riding
  • nevr2L8
    • Feb 2007
    • 131
    I installed H&R lowering springs all around last year and cheaped out and put KYB shocks on as well.
    I just got the car out of storage in the middle of pothole season this year and this setup is noisy and rides too rough.
    Should I put the stock springs back on or is there some other solution to this issue?
    Thanks
    Paul
  • PDX_MTECH2
    • Apr 2026
    • 6
    My car came with the red H&R race springs and I've experienced a very similar thing. After talking to a few guys that run the Spec class out here in the PNW it seems the general consensus is H&R is junk. I plan on switching to full Ground Control at some point.
    -1991 BMW 325i M Tech II S52 Swapped
    -2023 BMW X3M Competition
    -2021 BMW M2 Competition
    • Zzyzx85
      • May 2012
      • 131
      Are the spring pads still on it?
      - '89 325i 4-door, Alpinweiss, 5-spd swap (and lots of maintenance) in progress
      - '03 M3, Imolarot, 6 speed
      • nevr2L8
        • Feb 2007
        • 131
        I would have to look but I am pretty sure they are. The coils sit on top of each other so there is no possibility of compression. I think the bump stops are touching and that why I hear the springs rattle, like they are loose,
        I also wonder if my choice of shocks was part of the problem and a stiffer shock might help?
        I wonder if anyone makes a thicker pad for the shorter springs?
        • PDX_MTECH2
          • Apr 2026
          • 6
          There is compression but not a lot. H&R designed them with 'dead' coils in the middle on purpose. Looks like a bad design in my opinion but it serves a purpose. Are the KYB's designed for a lowered ride height? If not they may be part of the problem. I have Koni in the rear and the ride is okay but I feel like it be better. Noise on my end is mostly from sway bar.
