M3 steering rack vs normal steering rack (settle a dispute)
  • Kruzen
    • Mar 2004
    • 5603
    Is there any difference?
    Who doesn't love a little BBQ?
    Griot's Garage at a Deep Discount
  • Fred
    • 659
    The position of the teeth are different.
    '86 325 2.8i stroker - Arctic Blue
    '11 328i Sports Wagon - LeMans Blue
    Strictly Eta
    • Kruzen
      • Mar 2004
      • 5603
      continue...
      • Stu Mc
        • 4083
        Yes, the E30 M3 rack is different from the 318/325 E30 rack. Mine is 3.5 turns lock to lock (m3 rack) vs. over 4 turns with the standard 318 rack. I'm unsure of any other differences; it's been a while.
        hth
        • Kruzen
          • Mar 2004
          • 5603
          hth
          what modifications are necessary to run an m3 rack instead of a standard one?
          • JasonH
            • 434
            I just installed an E30 M3 rack on Friday and no modifications were necessary.
            • Kruzen
              • Mar 2004
              • 5603
              superb.. i think i know what i'll be getting.
              • M42Technik
                • 9781
                Be warned, it will not work without modifying the rack itself if you have a car that has an airbag.
                Reminiscing...
                • UNHCLL
                  • 8790
                  325i rack = aluminum case
                  M3 rack = Steel
                  M3 rack = 3.5 LtL
                  325i= 4.2 LtL IIRC
                  CL
                  ~with e30 m3 rack
                  Below the radar...
                  • Rob
                    • 8166
                    and if the donor m3 is a late model that has an airbag?
                    BEERTECH
                    • M42Technik
                      • 9781
                      Then plausibly it will fit. Just make sure its from an M3 with the airbag then.
                      Thanks Rob.
                      Reminiscing...
                      • Kruzen
                        • Mar 2004
                        • 5603
                        what has to be done to the rack?
                        • James Crivellone
                          Head Janitor
                          • 6304
                          Why, I swapped a 1990 M3 Steering rack into mh 86 ETA and it bolted right up, just unbolt the steering column right at the flange at the rack, pull it out, installation is reverse.
                          all the hoses are the same, same tie rods, etc.
                          I fail to see the issue with airbag based cars
                            • 37829
                            James and others, would you say it was worth the money for the M3 rack?
                            Classic BMW Specialists
                            Grover Beach, CA
                            www.BimmerHeads.com
                            • James Crivellone
                              Head Janitor
                              • 6304
                              My wheel follows the curv of the road now, which I like alot.
                              I got the rack for about 200 bucks, (maybe 250 I forget) so it was worth it to me, seeing as it only had 86K miles on it.
                              the E36 M3 rack is another great option, however I am more then happy with the e30 m3 rack
