What spring rates to go with?
  • optimusp517
    • Oct 2005
    • 797
    Ordered some GC coils.
    Here's my usage:
    daily driver
    no track days
    no autocross
    wants a slammed ride or low ride
    don't want too much bounce, and don't mind stiffness
    Trevor from GC told me 375/475. should I just go with that and listen to them or something harsher?
    Also btw what spring rates does H&R cup kit have?
  • 318isbmw
    • Nov 2005
    • 2843
    Mine are for roughly the same purpose and I just got 375/450, and I know beirbrenner also ran 375/450 I believe it was, its why I ended up with mine...
    • e30this
      • 3580
      if you dont mind a stiff ride. I would go with 500 700.. Its not to to stiff and when you hit a hole or bump its like one bounce..
      Im running them now and I think its perfect.
      • z31maniac
        • 17566
        Buy my used 350/500 springs.
        Great street setup.
        www.gutenparts.com
        • optimusp517
          • Oct 2005
          • 797
          no other inputs???
          • brn2ply7
            • 301
            I also run a similar setup to e30this except am running stock front and no rear bar with a 450f-700r setup and it is really worth the bumpiness. And like he said its just one bump. If you pick up adjustable shocks then you can just set them soft for when you don't want the handling capabilities. My car set soft really rides pretty normal lol.
            89 325i parts car
            90 325i in progress
            ground control 400f 700r-koni adjustables-koni adjustable sways-reinforced control arms-ground control camber plates-e36 cabrio shock mounts-4.10 lsd-5 speed swap in the works
            --tryng to join the schwarz army one day at a time--sigpic
            • Hodge
              • Jun 2008
              • 424
              I have 350/475 springs and it rides great.
              And my car is slammed.
              E30- 1989 325is
