I just finished my rear wheel bearings and I am stuck on reinstalling the rear axles. The splined portion will not fit back into the hub. I have cleaned the splines on both the hub and the axle and applied anti-seize lubricant to both sides as well. I've hammered them a bit from the differential side and I have made some progress, but I'm afraid of doing harm to the axle itself.
When removing them I used a 3 claw puller to hook onto the hub and push the axle out, and it definitely was difficult doing that. But for the reinstall, that tool obviously won't work because i need to pull instead of push.
Any advice/help would be appreciated.
