e36 rack worth it?
  • jakeb
    • 1909
    e36 rack worth it?
    I am going to be pulling my m50 soon to drop in an s52 and have been thinking about swapping in a e36 steering rack. Just the standard 3.2 LTL rack. My e30 rack is fine...no leaks or issues but I know it would be a lot easier with the engine out.
    So it is worth it?
    The swap sounds simple enough. I have an airbag car so I just have to cut the plate out a little bit, nbd.
    I can get a e36 rack for $75...
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
  • 87Blue325iC
    • Apr 2006
    • 1111
    So it is worth it?
    For $75 and you have the car tore up anyway - yes, it is worth it. I put in a e36 rack when my original rack died. It wasn't my daily driver and I put off getting the car aligned after I did the swap. I hated the steering - was very twitchy and didn't feel safe. I finally got the car aligned and it is 100% better - quick steering and feels solid - but really don't know if it was worth the extra $$ from stock.
    Aaron
    • gearheadE30
      • Jun 2007
      • 3734
      definitly worth it. It is probably the single most 'modernizing' thing I have done to the car. It doesn't feel nearly as archaic now; just make sure you ger a good alignment.
      Project M42 Turbo
      • Hey-U
        • Mar 2008
        • 560
        Just got back from the alignment shop this mourning after doing the swap. LOVE it!
        • 87Blue325iC
          • Apr 2006
          • 1111
          Makes all the difference!
          Aaron
          • OrganicMechanic
            • Jan 2008
            • 1719
            yes it is worth it.
            the only one up is the Z3 rack. If you want your steering to be telepathic, then do it.
            join the E30 Cabrio owners gruppe
            click here for details
            • TrentW
              • 2815
              Curious as to what is better about the E36 rack. Believe it's shorter turning radius, but is it "quicker" also? Enlighten me.
              • BraveUlysses
                • Jun 2007
                • 3781
                Yes, significantly quicker, depending on which e36 or z3 model you use.
                • CorvallisBMW
                  Long Schlong Longhammer
                  • 13039
                  It doesn't shorten your turning radius, it makes the steering 'quicker' (i.e. for any given amount of movement of the steering wheel, your wheels turn more)
                  • TrentW
                    • 2815
                    So what's the best model & year rack to use?
                    • yberther
                      • 1246
                      z3
                      Flickr
                      Originally posted by Indecline06
                      For some reason, when I get super duper ultra stoned... The M30 motor reminds me of big bird from sesame street.
                      • TrentW
                        • 2815
                        ^^^Any year the same?
                        • yberther
                          • 1246
                          search? there have been sooo many threads about this.
                          Flickr
                          • TrentW
                            • 2815
                            You could've answered my question in less time than it took ya to type that response, but thanks for the info...
                            • wagonizzle
                              • Sep 2006
                              • 443
                              From what I understand, 95 m3 rack is 3.0 lock to lock, and is the most desirable. All other e36 racks are 3.2 LTL, and the z3 is 2.7 LTL. These last two racks have the SAME RATIO, with the z3 simply having less travel.
                              For comparison, standard e30 is 4 turns LTL and e30m3 is 3.5
                              Originally posted by chileelky
                              amaze about the enthusiasm e30 generate
