Cosmo Racing Coilover Kit
  • !kid
    • 1362
    Originally posted by e30this
    Nope I had the same ones that V V V he had...
    Yup I had the same thing as you, The problem was all around each spring was adjusted about 1/4 inch difference...
    how did you set your ride hight?(what did you messure to get correct ride hight for LF RF and LR RR) or did you corner balence?
    :borg:
    • e30this
      • 3580
      I measured the pinch weld..
      • !kid
        • 1362
        the proper way to messure ride hight is from the bottom of the wheel arch to the center of the bottom of the rim
        i guess ill keep searching formore info on these springs before i make up my mind
        :borg:
        • e30this
          • 3580
          Whats the difference? What if my wheel arch is fucked up and one sags lower then the other? I know for sure that my passenger rear quarter sits a tad lower then the driver side. Factory error? Maybe.. I still figure pinch weld to ground is the only way to go.
          But then again e30s always have that funny lean.
          • downernsp
            • Mar 2008
            • 1931
            Is all you're looking for is a street/track car set up with a drop? If so look up H&R street or IE Stage 3 hope that helps also another thing to remember one will always say what they think is best, but is it best for you? that is the real question.
            • !kid
              • 1362
              i was thinking going with a spec e30 suspension set up but 400$ for springs !! damn thats alot. good chance ill go with billie sports or koni's i am just not sure what spring to go with. the car will see auto x and track events also next year i want to try and compete in a time attack event.
              the IE stage 3 springs have the same spring rate as the H&R race springs and are 100$ less.
              :borg:
              • lucky7
                • Jul 2005
                • 692
                im thinking about these coilovers more and more. i used to blow all my money on my car, and had no problem dropping $1500 on suspension. and even still, my cars never see the track. lol, i just want better handling, and low. normal springs just dont fit the bill.
                billies and cosmos fit the bill (price wise). but if i can get better performance with koni's and cosmo's, that might be the best route (for me).
                -Dane
                diving board division, bishez.
                • awestun
                  • Apr 2009
                  • 196
                  but IE3's sit higher.
                  • lucky7
                    • Jul 2005
                    • 692
                    they all sit too high for an early car, IMO. :D
                    but i thought the IE3's were supposed to lower a TAD more than the H&R's. hmmm. either way, its not enough. haha.
                    -Dane
                    • !kid
                      • 1362
                      does this harm your suspension performance?
                      :borg:
                      • 1mz
                        • Jan 2009
                        • 641
                        i have em right now, ill make sure to post a review on my thread but the car wont be driveable for another month... and the ride will be garbage because I'm running the stock struts until theyre destroyed *cringe* (flamesuit on)
                        http://l0st0n3.mybrute.com
                        http://l0st-0n3.mybrute.com
                        Work in progress: 1991 318i m50 swap
                        Feedback thread :up:
                        I prefer having a female in the car at all times. They generally smell good, but you do have to put up with that hole in their face.
                        • 87e30
                          • Jul 2008
                          • 5676
                          Cosmo's only save like 200 dollars and you then have to wonder about the quality of the spring/perch/etc.
                          I just hate everyone.
                          No need for discretion.
                          • lucky7
                            • Jul 2005
                            • 692
                            they save $200 over what??
                            -Dane
