Strut Mount Washer(s)
  • SpecM
    • Oct 2005
    • 4531
    I mis-placed the big bronze-colored washer that sits under the strut mount, when installing my m3 springs and Billy Sports a few weeks ago.
    First of all, how important is it? I would rather replace it, so maybe I can bum one off somebody, or someone could post the dimensions so I can nab one at work?
    Bottom line, I need to see a picture or one so I can get another...
    1989 cirrisblau-metallic 325i
  • SpecM
    • Oct 2005
    • 4531
    37X2,5MM ZNS3231336776760
    this is the part number I found on RealOEM... 37x2.5mm? What dimension is that referring to?
    • E30SPDFRK
      • 5716
      Diameter and height I would assume.
      Byron
      Leichtbau
      • Philo
        Ich esse kleine Kinder
        • 3334
        Are you talking about part 6? If so, you do need that. Thats the only thing keeping your strut from pushing through the bushing/RSM and on the the top washer, part 12.
        -tim
        Originally posted by Jordan
        I like the stance
        • SpecM
          • Oct 2005
          • 4531
          No, for the front... its p# 8 in the diagram of the front strut
          • Aptyp
            • 6584
            Come on down, man, you know I have 1 or 20
            • Philo
              • 3334
              Gotcha. I didn't see you specify front or rear, so I assumed rear. It's not extremely important, but I would have it there. It is a fairly generic as far as the size goes. The diameter is 37mm and the thickness is 2.5mm. They don't specify the hole size, so I would assume as long as the strut can pass through it, you're fine.
              -tim
              I like the stance
              • SpecM
                • Oct 2005
                • 4531
                Got some from a Stu here in Winston, thanks Art!
                And thanks Stu!
