car vibration at 55mph need help!
  • amiller07
    • 930
    drives great until i hit about 55mph then vibrates. then around 65mph it kinda goes away but i can feel it still. then at 85mph it gets worse like at 55mph.
    any ideas? help me pls.
    thanks
    "no, i didnt slap u...that was my hand giving ur face a high five"
  • 87e30
    • Jul 2008
    • 5676
    ON or off throttle? Only in gear or in neutral too?
    I just hate everyone.
    No need for discretion.
    • E30_fiend
      • Apr 2006
      • 7348
      tire balance
        +1 on tire balance. but it could also be a bent wheel, bad tire, worn struts/shocks, or worn suspension parts..
        • E30_fiend
          • Apr 2006
          • 7348
          tire balance has those same symptoms on every type of car. Vibration comes at 55 and leave around 65 and comes back after 80. I would definitely take the car in and get the tires balanced. Its the cheapest way to fix it. Start cheap then work your way up to the more expensive solutions
          • iX-treame
            • 440
            Check your lugs, make sure they are tight because when i had just bought my car and was driving it 6 hours from DC to home I had the same problem but it was very minor. It ended up i was only riding on 3 on each wheel, i tightened them up and added lugs and it was pretty much eliminated, now i need them balanced. my $0.02
            '88 325iX -Totaled
            '97 M3 - Sold
            '85 euro e30 Pete McHenry 2.8L m20 Stroker - Parting out
            '89 325is - Sold
            '95 540i 6spd
            '87 325is M Technic I s50
            • amiller07
              • 930
              well happens when on and off throttle
              fronts are brand new tires and balanced would the back need done? idk if they are still ok i got them from a friend.
              i had a balljoint go out on me so i replaced it but would that have F'd my strut?
              thanks for your help
