I cant get these bloody things on. I did a search and all I gathered is that a soak in hot soapy water will allow them to slide on "easily". Tried that and its a no go. Any other tips?
Rear sway bar links
To get them off, use a bit of WD40 or similar on the bushing. Then just wiggle back and forth while trying to pull them off.
To get them on, use straight liquid soap or even WD40 should work. Same deal as above - wiggle and push.
They won't budge unless you have something to reduce the friction.Comment
