Best front and rear strut bar
  • nutrof
    • 43
    I have IE III's race with billys on 17x7.5 ESM's... whats would be the best front and rear strut bars?
    Also, ae there adjustable front strut bars?
    86 e30...
    Ps.. please excuse the typos, I just had a few drinks....
    The best front strut bar will be the cheapest one you can find, which frequently is the Sparco bar. There's nothing to be gained from a rear strut bar, so spend that money on something that matters, like better brake pads for example.
    • Liam
      • 753
      I'm sorry to have to be the one tell you this but you are incorrect.
      I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃xS : φ(x)) → (∀xS : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
        And the evidence for that assertion would be?
        My assertion is based on the fact that the rear shock towers only anchor the top end of the shocks and the rear suspension is a conventional spring/shock configuration, not a strut type suspension. Since rear wheel alignment is determined solely by the trailing and sub frame geometry, movement of the shock towers has no affect on wheel alignment.
        • lov-e30
          • 16548
          gets pop corn...sits back....
          Oh boy, I smell a ban
          @IRON-E30 aka Edwin:D
          • Liam
            • 753
            It's not the shocks that are causing the flex back there, it's the force transmitted from the sub-frame causing twisting around the back of the monocoque. And... Just running a bar top to top in one load path isn't sufficient to control it either.
            Also this isn't only to control suspension compliance... It helps keep the shit from breaking (which was the first indicator we had that something was going on there).
            Here is a link with more information on this: http://www.evolutionzen.com/chassis-compliance.html
            My assertion is based on lab and track testing and failure analysis .
              I'm aware of the Zen brace and that logic. But I'm of the opinion that you'll gain greater chassis stiffness by running the roll cage rear braces to a point approximately above the upper spring mounts. And if you want even more stiffness (and the class rules allow) x-brace the rear tubes.
              You don't need either brace on a street car and on a race car (where it matters) you'll have a full cage to help with rear stiffness.
              • Liam
                • 753
                Not just "Zen" this information and testing is from several sources...
                I really don't have any stake in this anymore either if you want this stuff for an e30 you will have to go to Mason Engineering.
                I'm no longer involved in this end of the business... Strickly doing R&D and testing for another company.
                • jjmtools
                  • Jun 2008
                  • 34
                  tower bars
                  because the average age -25 years,and that the E30 chassis monocoque is constructed of spot-welded thin steel panels,it will benefit from additional add on tubular
                  tower braces front and rear.BMW engineers addressed this problem
                  Some cars will visibly show joint crack propagation from age/flex/usage.
                  The bars were designed to remedy this fact and common occurence.Amateurs are just that and sometimes broadcast incorrect technical mis-information
                  • Eric
                    • 5142
                    Originally posted by jjmtools
                    tower bars
                    I found a horizontal crack in my car just behind the fuze box. it is visible from the wheel well, and is not from rust.
                    • nutrof
                      • 43
                      So again... whats the best front and rear?
                      I have to stop drinking and posting... I've caused so much trouble already.
                      • Liam
                        • 753
                        Bottom Line: Mason Engineering is the very best.
                        • gearheadE30
                          • Jun 2007
                          • 3734
                          +1 on Mason.
                          Project M42 Turbo
                          • lifeiskaos
                            • 1709
                            mason for the rear, i'm a fan of the sparco in the front
                            • TrentW
                              • 2815
                              Is the Mason front bar a three bolt attachment on each side?
                              What's preferable on a street car--aluminum or steel?
