whos got Eibach sways F20mm/R16mm???
    gonna put these on my 11/85 build 325es and wanted to know what to expect. if anyone else has put these on there car, how much of a difference? are they trackable, or mostly for street. pics bla bla come flame whatever. i searched among many.
    Not sure what you want to find out.
    What to expect? less body roll
    How much difference? 0mm & 4mm
    Trackable? yes
    Streetable? yes
      I got them.
      Loves em.
        Make sure you have the mounts on the trailing arms reinforced or the swaybar will tear them off.
        Erik
          Erik
          Yep that happened to me last auto-x. Had to source a new trailing arm and welded on the reinforcements this time. If you upsize the rear bar, definitely get the reinforcements.
            Do you have a picture of the reinforcing not it broken. just want to see how it was done Thanks.
              Erik
              My car was running 350/500, with Eibach sways and 205 R comps as a track car for a few years before I got it.
              Sway bar tabs are as true as the day they came out of the factory.
              www.gutenparts.com
                Here is a picture of the reinforced tab.
                  That is okay, but not a lot stronger than the OE tab. To do it right a part of the reinforcement needs to bend up and be welded to the trailing arm. Tuner sells a reinforcement like that which triangulates the loads. I've bent the simple reinforcement, like above, on my Spec E30 (22/19mm IE sways).
