Which rear shock mounts?
  • RCWells
    • 3589
    I need to replace my rears, and am considering the JT rear mounts. Any advice?
    [THE 501 club - Founding Member]
  • RCWells
    • 3589
    Class? Anyone? Class?
    • Mystikal
      Wheel Fitment Expert
      • 9602
      I havce GC street mounts, like a bunch of others here. No noise, no complaints.
      • M-technik-3
        • 18946
        E36 or e46 Cabrio rsm work fine.
        • RCWells
          • 3589
          Alright. Anyone know about or have an opinion on the JT aluminum mounts?
          • jblack
            • Aug 2004
            • 98
            Seems with E36 and Z3 folks, the cheap way is E46 M3 mounts with Z3 reinforcements. For the aggressive street/light track, the JT's are OK, the GC's are perfered (GC is what I have). For all out track, solid monoball from GC or TC Kline is the way to go (no good on the street, and need a lot of maintance). I have GC on my track car - Monoball is not allowed in my class. Bimmerworld sells them - they have a liftime warranty, and James Clay (professional racer and owner of Bimmerworld) said he has never had to replace one under warrranty.
            No perceivable addional NVH (Noise, Vibration or Harshness). Easy install - bonus if you have externally adjustable rear shocks (ie - some Koni), you can remove the shocks from the car without tearing the trunk apart with the GCs.
            • AdamF 88iS
              • 2051
              GCs are not preferred. JT is the best RSM on the market right now. The Urethane bushing on the GCs is too stiff and can bend the shock shaft. The shock needs to be able to sway front to back a bit as the suspension travels, the JT allows for this.
              Adam Fogg- '88 M3
              Common sense- It's the new 'gifted'
              • trent
                I agree!!! JT Designs are nice!
                • RCWells
                  • 3589
                  Looks as though the JTs are a bit less expensive as well. They sound good to me. Thanks for the info/advice.
                  • e304lyfe
                    • 807
                    i have turner mounts... no complaints.
                    • hamann318is
                      • 3382
                      The BMW 318 is back. With a vengeance.
                      • e9nine
                        • 1890
                        E46 RSMs with Z3 plates....working fine so far after ~ 14months minimum
                        • Mike 91 318ic
                          • Jun 2004
                          • 429
                          I agree, I've been using E46 cabrio RSM's for 4 years and no problems...
                          M
                          • 500ke30
                            • Oct 2004
                            • 133
                            I got Ireland Engineering mounts and they seem to work fine. I bought these mounts because they came with a reinforcement plate to distrubute the load. Not sure how much it helps but it can't hurt.
                            Count down to 1,000,000 miles: 490,649 to go
                            • Cone
                              • 135
                              What about the ones from Rogue? Who has used those?
