How much to do a suspension rebuilt?
  • E88 Owner...But E30 Fan
    • Sep 2009
    • 40
    Hi,
    Im very close to pulling the trigger on an E30 and I understand that it will need a suspension rebuild after I buy it. Aside from the cost of shocks, springs, and sway(I plan on upgrading these) how much does it cost in parts to rebuild an E30 suspension?
  • White325is
    • Oct 2006
    • 5947
    right around 2200.00-2500.00 for all new parts.
    But it all depends on what parts you buy, where you buy them and what your after.
    • fiftytakedowns
      • 2460
      Over 9000
      [/url]
      Team USA Wrestling 67KG
      • ZM Blue Devil
        • Dec 2006
        • 13836
        Search under my user name. Our shop is running a special for suspension, we are in northern Nj zip 07040. It's posted under new england section.
        Levent
        %20levent@gutenparts.com
        Ladies:
          • Sep 2009
          • 40
          Originally posted by fiftytakedowns
          Over 9000
          Are you serious? Or are you quoting Vegeta?
            • Sep 2009
            • 40
            Is that including shock, etc...I cant imagine it being that much just for Bushings
              • Sep 2009
              • 40
              Unless that special runs through May I wont be able to take advantage of it. Im currently at school...sans a car.
              • White325is
                • Oct 2006
                • 5947
                This is what I have into mine.
                Reinforced and painted front subframe FREE
                E36 328 steering rack. FREE
                New inner and outer tie rods. 110.00 Shipped
                New control arms. 225.00 Shipped
                IE 22/25 sway bar kit. 250.00 Shipped ( it was used )
                AKG rear subframe mounts. 130.00 ( diff mount came with it. ) All shipping for AKG was about 20.00
                AKG trailing arm mounts. 95.00
                AKG dif mount. ( see above. )
                AKG offset cabs. 60.00
                AKG rear shock mounts. 100.00
                AKG Motor mounts. 50.00
                Ground control camber plates. 250.00 shipped
                New billie sports rear. 380.00 shipped
                New short koni shocks front. 250.00 shipped
                Turner motorsport SS brake lines. 115.00 shipped
                Ground control coilovers 500 front 700 rear. 430.00 shipped
                All new bolts for the front. 25.00
                IE rear camber kit. 100.00 Shipped.
                All new ebrake part, pads, shoes, springs kit, backing plates. 200.00
                Brembo blanks and PBR ceramic pads, caliper rebuild kits. 225 shipped
                I might have forgot some stuff but that gives you an idea.
                3115.00
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  You could do it with the stock rubber bushings pretty cheap. With new control arms, tie rods, upper strut mounts, rear shock mounts, and all new rubber bushings you would probably spend close to $500.
                  Originally posted by Gruelius
                  • b*saint
                    • 3794
                    I would say with ebay stuff like 500 bucks and thats on the high side. I did new control arms with control bushings, sway bar links, and tie rod ends for 190.
                    Ma che cazzo state dicendo? :|
                    • omar85
                      • 331
                      3115.00
                      i like this list. maximizing AKG parts is key.
                        • Sep 2009
                        • 40
                        I dont know that brand.
                        • kencopperwheat
                          King of Kegstands
                          • 14396
                          They make urethane bushings.
                          • She loved E
                            • Aug 2007
                            • 363
                            I'll be spending ~$1,700 on mine. That includes springs/shocks, control arms, CABs, swaybar bushings, shock mounts, RTABs (trailing arm bushings), rear subframe bushings, diff mount and used E36 steering rack. All rubber parts except a couple IE urethane bushings. Figure $80 for an alignment when the whole thing's done, and if you're lowering it a skid plate may be a good idea.
                            M119 M42 M62 S52 S62
                            • FredK
                              • 14763
                              Here's a list of stock replacement parts, including the stuff to do a brake job.
                              Lemfoerder inner and outer tie rods 110
                              Tie rod lock plates 1
                              Steering rack boot clamps 3
                              Lemfoerder control arms. 200
                              Lemfoerder subframe mounts 43
                              Sachs/Boge trailing arm bushings 40
                              Sachs/Boge offset front control arm bushings 40
                              JT-D lifetime shock mounts 30
                              Shock mount gaskets 1
                              Shock mount reinforcement plates 20
                              Front strut mounts 67
                              Motor mounts 80
                              Transmission mounts 20
                              ATE rubber brake lines 60
                              Balo rotors, OE type pads 220
                              Brake rebuild kits 18
                              Rotor set screws 4
                              $957
