Does anyone know off hand if this is true? I have an 1989 325IS - I'll measure this weekend but I think the cabrio front bar I bought (21mm) looked bigger.
22mm 325iS bar for automatics
explain this. Do you actually have proven data that supports this claim? It makes no sense why an auto would have a pigger sway bar than a manual. The added weight of the auto tranny wouldnt effect the cornering of the car because the weight is centered on the car.
If this is true, awesome. If not then we all need to have this info.
TaylorComment
M-tech's and Cabrio's got 21 MM bars these are the biggest bars I have seen as have normally all other E30 enthusiasts.
Lets see the facts to prove the existance of 22 mm auto bar.Comment
you are either reading it wrong or you are not taking into consideration the thickness of a layer of paint.
The only bars that came on iS models were 20mm. The largest bar made from the dealer was the 21mm cabrio bar. There is no reason at all for an auto iS to have a bigger bar.Comment
Guess you got an exotic one then. Better yet sure it's oem?Comment
Cool! let's add some understeer on our cars by putting only a bigger front bar and not a rear one! Am I the only one who has substantial understeer? While were at it let's run stagered tires and make the car plow some more. This seems like one of those m30 afm bigger is better things.
