GC Camber lates Adjustment
  • sharky
    • Jan 2005
    • 2672
    OK so I just installed my GC Plates with their CO kit w/ billy sports. I did not cut my strut housing at all as I try to keep my car unhacked like that. Anyhow, I have very minamal movement and can only get -1 on the plate before the alled screw hits the tower opening. Is there another way to get more adjustability without havking my towers.
    The opening in the strut tower does limit the adjustability of the camber plates. but even so i can get as much as 3deg of negative camber. I don't know that the marking on the plates have much meaning. Check the camber at the wheel.
    • DRTSRFR
      • May 2008
      • 1836
      Pics??
      Suspension tips here...
      http://www.r3vlimited.com/board/album.php?albumid=757
      • rwh11385
        lance_entities
        • 18403
        Yeah, pics. I have not cut my housings and could get -3 as well.
        • sharky
          • Jan 2005
          • 2672
          I will work on getting a pic
          • SkinnyVT
            • Nov 2008
            • 391
            This is before I switched to the new plates with the inset buttonhead bolts...just a little over -3°. Also keep in mind that the markings on the plates are for reference only, they don't represent the actual camber of your wheel due to the variation in people's ride heights and suspension setups.
            '86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
            • sharky
              • Jan 2005
              • 2672
              Im a idiot, I was looking at the allen head set screw and not at the strut bolt, I am reading about -2 on the plates, it looks like more to me and I need to raise a bit too. On a side note, I am running Billy sports with the GC plates and the top of the strut tube is only protruding enough to get the bolt on to sit flush with the top of the strut tube, I dont feel that comfortable with that but I dont know that may be the way it is, GC said the plates were for billys and they were brand new.
              • PaladinReed
                • 1524
                Interesting point, mine don't sit much lower than flush. At times I think it isnt threaded enough. Simultaneously, have you experienced any clunking over small bumps? I have some on the passenger side that has developed. Fully rebuilt suspension with less than 1000 miles on it. I don't want to thread jack but if we can figure this out in the same thread that would be optimal lol.
                Late model granitesilber 325i convertible FS:
                http://www.r3vlimited.com/board/showthread.php?t=293701
                • sharky
                  • Jan 2005
                  • 2672
                  car isnt running yet so cant report on clunking.
                  • Hellabad
                    • 807
                    This means check ALL of the bolts.
                    e30 in decreasing order of likelihood of making noise:
                    #1 by a mile: Gland nut holding strut in
                    #2 sway bar end link
                    #3 top nut at strut
                    #4 inner ball joint
                    #5 outer ball joint
                    jay form GC
                    Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
                    Ground Control Gallery
                    The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
                    • dirty30
                      • 3104
                      I had this same problem with mine a while back... I could not get the full range of adjustment without cutting out my strut towers. Shortly after that GC redesigned the hardware... It was too late for me though.
                      • sharky
                        • Jan 2005
                        • 2672
                        Jay from GC I am concerned about my top gland nut only being flush with the top of the strut bolt, doesnt seem to be all the way in, is this right?
