What to do? I want to get a front and rear brace. The problem is it appears every rear brace outside of the Mason brace only has 2 small ears where you bolt the brace to the rear shock towers.
The reinforcement plates I just installed is the Z3 styles so it distributes the load around the whole tower where it bolts. If you remove that install the brace you are really just putting the load right back onto the 2 bolts again...
Install the Z3 plate... then install brace?
