Urethane Sway Bar Bushings
  • Matt86es
    • Aug 2004
    • 616
    Does anyone know where I can get Urethane Sway Bar Bushings in 21mm and 14.5mm. I have the M3 and Cabrio sways to put on and I want to upgrade the bushings as I need new rubber ones anyways.
    has a 14.5mm for the 5er. Do you think that this will work? What would I use for the front?
  • Matt86es
    • Aug 2004
    • 616
    Nevermind...I just called Ireland Engineering and he is ordering me a set. He can apparently get them made in any size.
    • Matt86es
      • Aug 2004
      • 616
      Or maybe not...anyone know where I can get some?
      • DEV0 E30
        • Oct 2004
        • 8892
        http://theeurodepot.com/ , http://www.turnermotorsport.com/html/index.asp
        Maybe?
        • rs4pro3
          • 5808
          BMP had them also.
          85 325e 2.7 ITB'd stroker
          • Matt86es
            • Aug 2004
            • 616
            Thanks Ely, but isn't $80 kinda steep. I can get the whole Ireland Engineering reinforced sway bar bracket and urethane bushings for $120
            • Matt86es
              • Aug 2004
              • 616
              Has anyone used the IE rear billet alluminium mount?
              https://secure7.nexternal.com/shared...p&CategoryID=3
              • Matt86es
                • Aug 2004
                • 616
                Should I replace the End links when doing this as well? I'm sure that the original ones are on there and are 19 years old now.
                • rs4pro3
                  • 5808
                  I'd go for the Stronger Ireland Mounts.
                  • Matt86es
                    • Aug 2004
                    • 616
                    Yeah, I think for $40 more it would definately be worth it...plus once you get those mounts, I can switch out for $10 a pair bushings later if I upgrade to a thicker bar, b/c the mounts use a standard bushing instead of BMW one.
                    • Matt86es
                      • Aug 2004
                      • 616
                      I just ordered the reinforcement kit w/ urethane bushings today! They're shipping out on monday. Add the new endlinks shipping from BMA on Monday and I'm set. I actually have a few days off this coming week so I hope they hurry up and get here.
                      Anybody done the swap and have any hint/tips that aren't part of the normal process?
