I have the Bilstein HD's with Eibach Pro Sport (1.25" drop or so) with the IE sway bars on the 88 325is. Poly rear subframe bushings. With the TRM 15x8 wheels shod with BFG GSport 225/50-15's set at 30 front 32 rear psi, every little raised crack in the road jars the car.
It's almost as if the springs/shocks are just not moving at the initial point of impact on the sharp edge bumps. At higher speeds it's not as much of a bother, but below 40 or so it's just annoying.
I only have about 1K miles on the setup, but I would expect them to be broken in by now.
Any insight if this is the way it's supposed to feel?
