Alignment issues...
  • Brian 89 325i
    • 1450
    Alignment issues...
    Ok so my car was pulling to the left so I took it in for an alignment.
    Heres my specs
    IE Stg III's
    Bilsteins
    Sparco Strut Bar
    Offset strut mounts
    THR lollipops
    new lemforder LCAs and new steering arms
    My left front wheel was at -0.7 and my right front was at -1.4
    What might cause this? Everything else was the same, but the camber on the passenger side is way out. Im going to take everything apart soon and pull the spring pads and see if that changes anything, but thats kind of a lot to just be that.
    Thanks
  • asubimmer
    • 6482
    just put a slit in the spring pads if you don't want to remove everything ;)
    • Brian 89 325i
      • 1450
      oh, thanks.
      • Gnarles
        • Dec 2008
        • 342
        Could be a few different things. Has the car ever been in an accident? Maybe you have a slightly bent strut housing.
          You have damage to the struts or shock towers.That is the bad news, the good news is that the damage is minor and within the range of what adjustable camber plates can correct.
          • Brian 89 325i
            • 1450
            Im not sure if the car has ever been in an accident, but the strut tubes/shocks came off my 89 and I know that one had never been in an accident.
            Ill have to check my shock towers, they look pretty straight and my sparco brace fits really easily.
