I am having trouble removing the u-joint/s-joint in my lower steering column. I did a search and the bentley is of no help.
I hit a nasty pot hole a few weeks ago that took out my oil pan. With it, it got my front subframe. The impact separated the sacrificial joint section of the u-joint. I need to remove it and either install a new one, or press the joint back together and re-install it. It being separated causes some play in my steering.
I know I need to completely remove the bottom 13mm bolt where it connects to the steering rack and at least loosen the top bolt where it connects to the upper stearing column. I removed both bolts and neither end of the u-joint will budge off of the splined shaft.
Any Suggestions?
Any Suggestions?
