billy sports
  • Smatt90IS
    • 151
    billy sports
    i have a 1990 325is and i found a good set of used billy sports in a junk yard on an 84 318 and i was wondering if they would work in my car the guy is giving me a killer deal so if there is a way to make it work that is not terribly ghetto lmk
  • chadthestampede
    • Jul 2008
    • 3601
    nope.
    Originally posted by LJ851
    Feedback
    • Smatt90IS
      • 151
      what about the rears?
      • Stu
        • 4083
        Get the strut housings and they will bolt up, but you'll lose ABS...like I told you earlier. ;)
        • chadthestampede
          • Jul 2008
          • 3601
          no again. The 318 has 45mm strut housings as opposed to the 325's 51mm ones.
          EDIT: unless you do this, of course:
          Feedback
          • Stu
            • 4083
            Try again. 45mm housings bolt to the shock tower, 17mm and 19mm at the tie-rod and control arm pickup.
            • chadthestampede
              • Jul 2008
              • 3601
              I ninja edited. Either way, probably not worth losing abs, imo.
              Feedback
              • Stu
                • 4083
                Gotcha, I think he has the opportunity to get a full set from an early 318 for super cheap, which might be worth it depending on the condition.
                • e34john
                  • Apr 2006
                  • 3599
                  Build some sort of sleeve for them. Some guy in a local race shop did the same for his car. Or buy and resell and use the profits towards the right ones.
                  • IRON-E
                    • 16548
                    ^^^this
                    @IRON-E30 aka Edwin:D
                    • Smatt90IS
                      • 151
                      could i drill the brake housing to fit the abs sensor or would it be a waste of time?
